2 members (Otto Skorzeny, 1 invisible), 92 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#1166220 05/20/2016 6:51 PM
On my 58 half ton with a 235 the shop manual calls for a special lock washer for the rear engine mounts that bolt thru the bell housing. One of mine on the passenger side was missing. I thought the bell housing bolt holes were threaded so I thought I threaded the bolts thru. Some how one fell out. When I removed the engine and installed the new engine I do not remember there being locks and nuts on the top side of the bell housing legs. Anyone know what lock washers they are referring to in the shop manual.
6571 #1166232 05/20/2016 9:06 PM
Riding in the Passing Lane
They originally come with a lock plate. The tabs fold over the hex on the bolts. I always discard these & use split ring lock washers. There is a tube spacer that goes in the middle of the mounts. If this is missing the mounts won't work right. If the threads in the bell housing are wiped out you put a nut on the top side.
1972 Chevy c10 Cheyenne Super
That is what I did. Used a split lock washer, but since I fastened it down with the nuts and lock I can really feel the vibration of the engine now. Some installed a slightly radical camshaft when they rebuilt the engine.
6571 #1166287 05/21/2016 3:41 AM
You shouldn't feel any metal to metal type vibration if the motor mounts are installed correctly.
The following list is to confirm you have all of the right parts for the rear mounts. There is an Upper Rubber Mount (U-shaped), a Lower Rubber Mount (small rectangle that fits up inside the cross member), a Spacer, a Lock plate and the Bolt.
The lock plate gives the bolt a larger surface area to press against and locks the bolt from turning. If you just use a split ring lock washer there's not much keeping the bolt from being pulling up through the Lower Rubber Mount when the truck frame twists or there is heavy engine torque.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I have everything you described except the lock plate. Can you post a picture?
6571 #1166304 05/21/2016 9:24 AM
Sir Searchalot
Sir Searchalot
The pre bent portion fits over the lower rubber and the portion near the bolt head has tabs that are bent up after torqueing. This prevents the bolt from rotating.
These can be found on trucks up into the late 60's +?. Junk yard or DIY.
The bell housing ears are threaded. Someone may also put a nut on to "lock" it that way.
Thanks for the photos. I have everything except the strap with the tangs to lock the bolt head. I will have to make those. There are no junk yards left around here with trucks that old.
6571 #1166338 05/21/2016 6:16 PM
Sir Searchalot
Sir Searchalot
I have PM'ed the links.
6571 #1166357 05/21/2016 8:59 PM
PM sent
1959 3100 Apache Fleetside
