1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | I have located a 39 COE and would like to know what modern chassis would be the best and what problems that you had mounting the cab. I will add pix once I get it home. I also would like some help on the ID as it was on a tag, mounted in the cab on the firewall and the number that I got was 6VHO2 3350. Looks like it was a Van Nuys truck and is a 131" WB but what does the 02 and the 3350 mean? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Ha Brad; Very cool info on the COE. My 39 did not have a remote control shifter. Mine had a top loader trans. Do you have any info/photos on the remote shifter? My 39 COE was a 107" wheel base Tow Truck.
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am no expert on the COE's but all that I have looked at from mid 30's to the 1st Series 55 had a remote type. Spanky or one of the COE experts will be along I am sure with the correct answer. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your serial number breaks down as follows; 6VHO2 3350 6 = Oakland plant VH = 1039 COE w/ 131" wb 02 = February 3350 = unit number starting with 1001 Mike B  | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Thanks for the two sites to view, I have stored them in my quick hits. | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | I am pretty sure that it is a remote shifter, not sure as the place where the truck was at was very close and not easy to get to. Once I get it out in the open where I can be sure, I will let you know and also try and figure out how to add pix. | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | I really like the pix, that you sent, I will have a lot of question about the frame/engine/real axel and the front sheet metal attachment once I get started. The way the truck sits and looks is a WOW!! | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Thanks Brad, I really enjoyed looking at them, the first ones were great, I think the guy that I bought the truck from has one of them on a DVD, that he will give me. | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Thanks, I was not sure of the 02 as what I had read was not really clear on these digits and I was looking for more digits in the 3350 number. Is the data plate in the correct location on the inside of the firewall, almost in the middle above the floor pan? It is attached by two screws they are the internal and external type.
