| | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | As far as I can see the hinges only adjust up and down against the A pillar. Is this correct? I want to adjust the lower hinge outward just a tad for when the door is currently closed, it's outer surface is more inward as compared to the outer surface of the pillar.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...link... ...section 10... Not sure how one goes about bending the hinge? | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I already thought of simply enlarging the hinge body holes horizontally but was hoping I was just overlooking a simpler method. I also can't imagine tweaking the hinges.
Thanks. Later this week I might address this.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I couldn't wrap my head around the hinge bending deal, so I enlarged the hinge holes. It doesn't take much.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Thanks. Will give it a try after my camping trip.
| | | | | Joined: Mar 2010 Posts: 10 New Guy | | New Guy Joined: Mar 2010 Posts: 10 | | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | I agree w 52Carl: I needed also to bring both doors outboard a bit to satisfy my need to have the doors flush w the body. I enlarged the holes horizontally....can't imagine bending those hinges w any chance for success. Good luck. Dave | | |
