3 members (Otto Skorzeny, 2-Ton, tclederman), 58 guests, and 3 robots.
Topics128,089
Posts1,056,116
Members48,434
As far as I can see the hinges only adjust up and down against the A pillar. Is this correct? I want to adjust the lower hinge outward just a tad for when the door is currently closed, it's outer surface is more inward as compared to the outer surface of the pillar.
Craig
...link...
...section 10...
Not sure how one goes about bending the hinge?
I already thought of simply enlarging the hinge body holes horizontally but was hoping I was just overlooking a simpler method. I also can't imagine tweaking the hinges.
Thanks. Later this week I might address this.
Craig
I couldn't wrap my head around the hinge bending deal, so I enlarged the hinge holes. It doesn't take much.
Thanks. Will give it a try after my camping trip.
Craig
Post #17 shows how to bend the hinges with a vise and a pipe wrench
http://67-72chevytrucks.com/vboard/showthread.php?p=6045951#post6045951
I agree w 52Carl: I needed also to bring both doors outboard a bit to satisfy my need to have the doors flush w the body. I enlarged the holes horizontally....can't imagine bending those hinges w any chance for success. Good luck.
Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
