2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The repair of my '64 C10 3 speed tail shaft has gotten harder. Now I'm replacing bearings in the tranny. After complete disassembly we found no 'energizing springs' in the tranny. They need to be there for the synchronize to work correctly. They are unavaible from my tranny source "Anaheim Gear". Anyone know where I can source them? Thanks.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Are you saying that they are missing? It shouldn't have worked without them. If they are there but worn you can move them over one notch to get a good locking surface. I have some but they have worn spots. (but useable) I use AG for bearings & seals but like most suppliers of this stuff their stock of hard parts has dried up. Send me a PM and I can get you some. Fred
| | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | You can try www.garagemotorsports.com, talk to Mike, knowledgeable guy. Helped me out with my 3 sp.w/OD, ended buying a rebuilt unit from them. Not cheap, but it works perfectly. I tried moving the energizing springs a notch too, but it didn't work for me. Good luck
'59 Apache ‘21 Beta 390RS ‘18 BMW R1200RT '12 Ford Flex '13 Aprilia Tuono ‘11 Ducati Hypermotard Salisbury, MD
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'll admit I'm working from an exploded diagram from the repair manual. We were careful upon disassembly working on a large steel table that's 'tilts' toward the middle. We have looked to identify all the parts and they are not there unless they are somehow attached to a gear face and we missed them. We were thinking the tranny had 'eaten them', or left out in a previous rebuild. All the parts have been through a good cleaning so are squeaky clean. I'll look again and get back to you as the guy who is helping me is out of town tommorrow getting an update on his '54 build.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Try this guy. Has been in business for a long time and has a lot of parts for Borg Warner and Muncie. This is not his main job, so you may have to call in the evening or leave a message. http://www.dandltransmission.com/borg.html | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Has been several weeks on this tranny and I need to finish this up. All is well and good with the 3 speed. Got it together CORRECTLY yesterday and it is in fine shape with almost everything new. BTW, the energizing springs were there, we just didn't know what we were looking at. First I need to thank "rfs56trk" for all the phone calls on trying to get this tranny right. He was a great help to us, 'the unknowing'. Second, a lot of parts are no longer made for these transmissions. But rfs56trk had me contact "Dave Waugh Transmission" , 562-325-7539, who has many of the parts you will need including the 2nd and 3rd clutch hub. In conclusion, finding a really good used tranny for these trucks will be very hard to do as they are old and have been really worked hard. Parts are there to make them run well for another lifetime. Let be clear on this one point. Attention to detail is everything. They will not go back together incorrectly and work...I think you know why I know this. Thanks.
| | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | Back in the day drag racing. Ive tore up dozens of those Muncie 318 transmissions. I would take parts of several and build one. It wasn't never any big deal for me to take one apart and put it back together. Today Ive got a good supply them. I even got two of the 319 overdrive ones. Ive sold a member named Dellman two of the 318 three speeds for his trucks. good used transmissions for $100 each. | | |
