| | | Forums66 Topics128,164 Posts1,056,982 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | this may be the incorrect forum, so i apologize in advance, but what hardware do i use to attach the headlamp buckets to the fenders on my '59 fleetside. Looks as though screws (8) should be used, correct?, but what size? also looks like i need to make my own gasket as i can't find them for the '58 or '59's at parts houses...
thx pork
1959 Chevy Fleetside 3100 Series BBW
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Pan head phillips type screw. #8 maybe? I don't know for sure(some one here will). Gasket? The same as for a Task Force(55-57)? I don't think the Bucket changed much...again some one here will know. Sorry, not a lot of help.
Steve H
| | | | | Joined: Nov 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 39 | Here is the hardware for mounting the buckets to the fenders. My '58 had a paste that is similar to seam sealer between the buckets and the fenders. I am just going to use seam sealer from a caulking tube. Chad | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | you can use seam sealer or go to an RV store and get a roll of butyl tape they use for windows. (about 10$). IT is about an inch wide, and stays soft. It is like plumbers putty but already flattened into a nice roll. Put it on the fender, peel the paper off, place your bucket and screw it in place, then peel off the excess. either way should work well, | | | | | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Steve, Chad and Mike I appreciate your input, links and suggestions. Going to order the hardware kit and i'll tinker with the butyl tape. thx pork
