2 members (klhansen, Samantha), 51 guests, and 2 robots.
Topics128,053
Posts1,055,778
#1165029 05/12/2016 11:31 PM
There was a good discussion a few months ago about this item and I don't recall its correct name. It just bolts onto the front end components and stabilizes the ride. Does anyone know what I am referring to? I remember Denny talking about it. Sorry I don't have a better description. Steve
ODSS Lawman
ODSS Lawman
Steve
You are referring to a sway bar my friend! One of the greatest bolt on's I did to my truck.
drive
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Here's some info I just dug up on a search for "sway bar"
https://www.stovebolt.com/ubbthread...r_installation_&quo.html#Post1097364
Riding in the Passing Lane
A steering stabilizer is a crossway shock absorber. I don't recommend one without power steering. I put one on a 55 I had & it was dangerous. Now a sway bar is like SWeet says, the best thing you can do to make them handle better. You can get a kit at Speedway or CCP.
1972 Chevy c10 Cheyenne Super
Here is one style after-market "stabilizer" kit.
Here is a simple after-market sway bar kit.
Panel body 47-55 trucks come with a sway bar assembly. Jim Carter often has used assemblies for sale. He also sells (or, he used to sell) the two different styles of rubber bushing sets.
NOTE: GMC sets are different.
I was just thinking about adding a steering stabilizer to the 48 2 ton.
There is a lot of "shock" in the wheel when hitting pot holes and bumps. This isn't bump steer. it's pounding in your hands
The front end alignment has been checked 1/8 toe in. camber good, caster is around 1-1/2 unloaded (factory spec - 1/2 degree curb, 2-1/2 gross.
Brand new tires 8:20 R20 12 ply steering tread on front, drive tread on rear.
Always used stabilizers in VW buses for the same reason.
Leo Offline
Moderator
Moderator
I still have my original sway bar.
ODSS Lawman
ODSS Lawman
Leo also drove his panel from Canada to Homecoming last weekend. I verified his sway bar works just fine. Then Leo returned the favor and tested mine as well!
eeeek
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Could someone explain how a sway bar works and how it will change the drivability. Thanks
Explanation and video.
Non-technical answer: It works like magic.
Thanks Tim and everyone who responded. After a trial run, I realize along with new shocks this is a important item to have. I should of had one when I had a VW bus! Steve
