| | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 19 New Guy | | New Guy Joined: Nov 2015 Posts: 19 | I have a 1963 c10 3.8, my rear axle is a 12 bolt and I am running with a 3.73, I have just tried to fit a 3.08 crown and pinion and the planet gear casing is to big now when I try to put back my half shafts, is there such a thing as I thinner casing.
RATZ
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | You need a different carrier assembly (the piece the "crown" gear bolts to. (ring gear on this side of the pond), or you'll need a spacer between the carrier and the ring gear. That's a common problem when changing ratios. Check online suppliers like JEGS or Summit Racing for the spacer rings. Jerry
