3 members (78buckshot, klhansen, 1 invisible), 152 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
Apprentice
Apprentice
Now that I have my winshield frame painted, I'm ready to install the new glass. I need some pointers on the proper, or best way to install the glass using the glass setting tape. Is it placed in the channel first and the glass slid in ? Does the tape get cut in the corners to lay flat ? The tape also appears to have more of a rubber feel on one side. It does not seem like it will slide together very easy.
I would appreciate any help, or experience anyone can pass on.
Thanks, Jim
Jim
You have to brush the setting tape w/motor oil, the slicker side goes toward the frame. Cut the corners in a vee to lie flat. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Apprentice
Apprentice
Thanks Brian, I didn't think of motor oil, but I,ll give it a try.
Thanks again, Jim
Jim
According to the shop manuals, it also makes the tape swell after sitting overnight or so, making for tight seal. Use gasoline to loosen old tape to remove glass. Gotta love that old technolgy!!Brian
