6 members (Wayne67vert, treegrower, Phak1, Bill Marlow, 55shaker, 1 invisible), 41 guests, and 0 robots.
Topics128,089
Posts1,056,005
Members48,430
#1165460 05/15/2016 6:31 PM
I have a 1963 c10 3.8, my rear axle is a 12 bolt and I am running with a 3.73, I have just tried to fit a 3.08 crown and pinion and the planet gear casing is to big now when I try to put back my half shafts, is there such a thing as I thinner casing.
RATZ
You need a different carrier assembly (the piece the "crown" gear bolts to. (ring gear on this side of the pond), or you'll need a spacer between the carrier and the ring gear. That's a common problem when changing ratios. Check online suppliers like JEGS or Summit Racing for the spacer rings.
