1 members (walter74),
75
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Now that I have my winshield frame painted, I'm ready to install the new glass. I need some pointers on the proper, or best way to install the glass using the glass setting tape. Is it placed in the channel first and the glass slid in ? Does the tape get cut in the corners to lay flat ? The tape also appears to have more of a rubber feel on one side. It does not seem like it will slide together very easy.
I would appreciate any help, or experience anyone can pass on.
Thanks, Jim
Jim
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You have to brush the setting tape w/motor oil, the slicker side goes toward the frame. Cut the corners in a vee to lie flat. Brian | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thanks Brian, I didn't think of motor oil, but I,ll give it a try.
Thanks again, Jim
Jim
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | According to the shop manuals, it also makes the tape swell after sitting overnight or so, making for tight seal. Use gasoline to loosen old tape to remove glass. Gotta love that old technolgy!!Brian | | |
