2 members (mick53, J Lucas),
133
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11647 01/20/2002 2:34 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Hi all. I just picked up an NOS set of Thomas Hi-lift magnesium adjustable rocker arms for a 235 chevy. I'm just curious if anyone has used these or know anything about them. I plan on using them in my 261 i'm going to build and am wondering if they are any good. Thanks for any info.
Chad
1955 Chevrolet 210 2 door Sedan a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
#11648 01/20/2002 2:57 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Look close you sure they aren't 216 or GMC? | | |
#11649 01/20/2002 3:12 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | No, the box reads:
Thomas Magnesium Rocker Arms Chevrolet 235 ENG #1008 HIGH-LIFT NEW-with replaceable tips
Do you know anything about them?
Chad
#11650 01/20/2002 4:41 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Hi Chad- Should only be 6 of them, right? 3 rights and 3 lefts? They go on the intakes and increase the valve lift on a stock cam because the ratio is 1.5:1 instead of 1.4:1. (if I remember right) Thomas, Barker, B&B and Fenton all made these in the '50's. One problem I've noticed with old magnesium when redrilling old Halibrand wheels is that it gets real dry and brittle when it's old. You may have a higher chance of breakage, especially if used with stiffer valve springs? | | |
#11651 01/20/2002 5:04 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | | | |
#11652 01/20/2002 6:19 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | Recently read a post on another site that said aluninum and etc rockers were only good for about 20k miles, and should be replaced in drag racing engines every 2 years. Something to do with the stress and the amount of stress. Kida like the the stuff that the airlines had to figure out a while back. If I was going to go afer them I would go for a steel rocker, with a roller, and clearanced for the lift of cam you want. Dennis | | |
#11653 01/20/2002 3:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Magnesium is a very brittle metal. In the 50's it was the wonder-metal of the time. Was outlawed in the 60's for use in lawnmower decks, too many people got hurt when rocks went through the housings, killing/maiming people. Personally, I wouldn't use them.
Aluminum rockers won't have the strength or hardness of a steel rocker. Add a little over 50% more material to get the strength of steel, but you can't come close to the hardness needed for the pounding on the valve stems. Okay to run, but definitely not a long-life product.
Fred 52 3600 69 C-10
#11654 01/20/2002 7:27 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Phat may have a better take on aluminum rockers, but a lot of guys use aluminum roller rockers for years with no problems .Might be more of a gimmick than a necessity on a street engine but the reduced friction is worth some free power. I'm taking Chevy v-8 here, to replace the stamped steel pivot ball rockers.Old magnesium stuff is a whole different story | | |
#11655 01/20/2002 11:28 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Tony, it's not less friction, but less mass to be moved, that much more power to the wheels.  Do they make a difference? Not enough to be noticed in a street machine. If you're talking about shaving hundreths on the quarter, yes, but not much unless you have a well-balanced engine.
#11656 01/20/2002 11:44 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | This is what Crane cams claims ;Gold Race (Extruded Body) Made from heat treated, extruded aluminum billet bar stock for ultimate strength. Needle bearing fulcrum and roller tip for maximum friction reduction. Improves response, increases HP and RPM, lowers oil temp. For most 4, 6 and 8 cylinder domestic engines. Different ratios, pushrod seat offsets and stud sizes available. | | |
#11657 01/21/2002 12:12 AM | | Anonymous Unregistered | | Anonymous Unregistered | Roller rockers just plain work.Less friction ,lighter weight(exp alumin) and no they dont have to be changed in a street engine.I have many sets out there with over 100,000 miles on them.(one set is in my snow plow truck now for over 10 years,racin rejects)BUT those mag racker are rare and a great coffee table item,dont use em .Nothing wrong with the stock steel not many fail ,just wear out(even then they are fixable).leave em inn the box neat item to talk about,but of no use in your 150 hp 235.really cool find!!!!  | | |
#11658 01/21/2002 9:45 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Okay Tony. I missed the roller part. Been so long since I looked at a set of them I forgot. Too damm old, I guess. The aluminum body means less mass to move, the roller bearings will do a lot for friction. But they're still not going to last as long as steel.
#11659 01/22/2002 1:01 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Hi guys, thanks for the responses. They are oxidized from sitting so long and I didn't think they'd last long because there just doesn't seem to be that much material there! I was surprised at how light they are! Much lighter compared to the stock steel rockers. Maybe i should just be on the lookout for the fenton, B&B, or Barker high lift varieties, since they are steel. Maybe your right Phat, I'll just use 'em as a conversation piece. They still got the instruction sheet with 'em so maybe i'll throw them in the display case. Thanks for all the responses.
chad
#11660 01/22/2002 2:56 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Hey Chad, let me know if you want to trade for another brand, I'm sure I could dig up a set out of my collection. Personally I would use whatever cam you want and not try to wake up a stock cam with high-lift rockers. | | |
#11661 01/23/2002 5:37 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Hi Barry. The 261 I'm going to build is going to be kinda hot so I'm not going to be using a stock cam. I think i'll hang on to this set and search for one of the other varieties. I've seen a set of fentons before but passed up on the deal. I'll keep my eyes peeled. Thanks for all the info everyone. Chad
