| | | Forums66 Topics128,261 Posts1,058,327 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 25 | On the 60 thru 66 Chevy Fleetside Beds you have a two piece side upper and lower what is the best way to seal that area to keep from rusting? 62 Blue Don | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Media blast it, epoxy prime it, force a bead of 3M panel adhesive into the seam, sand it smooth after the adhesive cures.
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | If you have the bed apart, consider one more step. On my 59 with a similar seam, I laid the bedside on sawhorses and after removing existing rust I drizzled Rustoleum red primer into the seam coat after coat until it quit seeping into the seam. Then sanded it smooth and followed up with epoxy and paint as described above. So far so good on the rust. I felt that if rust reoccurs it will come from the inside of the bed and it would be important to seal deep into the seam. | | | | | Joined: Oct 2014 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 25 | Thanks for the reply back guys. Its been awhile that I have been on here as I have been going to the doctor for Vein work and I can't do a darn thing just yet. If anyone has vein problems get it done as soon as possible because I waited just way to long. Thanks again guys as I knew you would come through as always 62blue Don | | |
