0 members (),
128
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,042 | Concidering including A/C in my project 1/2 ton 53 chevy. going to run 235 twin webbers blah blah blah, alum radiator electric fan no P/S, altinator. will I have to run a double pully? has anyone done this? how did you like it? The interior kit doesn't look too bad. keeping stock look, kinda.
| | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | I put AC in my stock 51, 228 six cyl. Now has alternator and 12 volt, which you have to do for the A C . It does OK, but gets a little warm if stop and go travel. My unit does not have a double pulley. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | 48 2 ton has dual W-1's on an Offenhouser manifold and Fenton headers on the 235. Powermaster alt. Mounted A/C on drivers side and used stock type single belt (wide). Major engineering project because of manifold and header clearance problems. A lot of modification to the mounting brackets and had to modify inner fender for it to fit, and add an idler pulley. Works fine. | | | | | Joined: Mar 2015 Posts: 4 New Guy | | New Guy Joined: Mar 2015 Posts: 4 | The Vintage Air bracket that I used had 1 belt for the crank pulley, water pump and a/c compressor. The a/c compressor had a double pulley that ran to the alternator. A/C compressor is mounted where the generator originally was installed. The alternator sits above the compressor about even with the head. Here is a link to a photo: http://i231.photobucket.com/albums/...xe%20Powerglide/DSC_2642_zps8de914c9.jpg | | |
