9 members (Gray_Ghost, cmayna, treegrower, Barney1951, UtahYork, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 33 | Sorry, if this was addressed previously. I searched and couldn't find an answer. So I have an original radio in my 1953 and the knobs are very loos on the pot shafts. They are repro knobs and I'm wondering if that's the issue. I don't know where they came from. Anyone else have this issue? Where do you get your radio knobs from? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | mattcorad5150,
Got my repo radio knobs from Jim Carter truck parts. They were loose also. Inside the knobs are some small metal clips. I used a pick on the flat side of the knob hole and carefully bent the metal clip up toward the hole in the knob. That tightened the knob up on the shaft. Be careful not to break the plastic.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Apr 2016 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 33 | Great suggestion, I'll check that out. Thanks! | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | you could put just a little (a little) silicon caulk in the knob hole. It will hold the knob on when it sets yet will allow you to pull the knob off if needed.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
