2 members (jmoore, 68ironhead),
86
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I have an 235 HEI setup from Langdons ; needing a cap&rotor. Anybody know part# or what make model etc Sent Langdons stovebolt an email...
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If it is coil in the cap type like the old HEI GM ignitions, go to your local parts store and pick one up for a 1980 Chevy 250. It should be HEI and use the same cap and rotor. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You can go to rock Atuo's web site and check out the cap and rotor and see. www.rockauto.com
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It has been years since I talked to Tom, but I believe the distributor started as a 2.8 V6. (sample picture)
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Ahhh... could have been. If so, an early 80's Chevy Celebrity with the 2.8 would have that type cap.
Airtex /Wells cap number is 5D1055 and rotor number is 4R1049
