| | | Forums66 Topics128,193 Posts1,057,246 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 17 | Got a '51 3600 that was originally delivered as a cab/chassis so has the short under-cab running boards. At some point in time someone installed a '54 bed on the truck. I want to install stock full length running boards. Will they still work with that '54 bed on the '51 truck? Al | | | | | Joined: Jul 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 66 | The bed has nothing to do with the running boards. The distance between the front and rear fenders is all that matters. you may have to move the rear fenders forward or back to get the proper fit. | | | | | Joined: Mar 2016 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 17 | Thanks. Yup, I lumped bed and fenders together as they were all put on at the same time. Since there were other body mods made in '54 I didn't know if the bed and fender positions were affected thus impacting that distance between front and rear fenders. If anyone knows what that dimension would normally be in '51 I would appreciate your posting it here. Thanks. Al | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The length of 1954 1/2 ton and 1 ton beds was unchamged compred to earlier years. The length of 3/4 beds increased by 3 inches in 1954. Wheel base lengths did not change. 1951 wheel base 1954 wheel base | | | | | Joined: Mar 2016 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 17 | Hate to say this but even though the bed and frame got longer the wheelbase stayed the same so I'll ASSUME the dimensions between fenders also remained the same. Now to locate long running boards. Thanks all for the info. | | |
