| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 31 Junior Member | | Junior Member Joined: Apr 2005 Posts: 31 | Ok, I was hoping you guys could tell me what you would recommend as paint to use on the timing cover, oil pan and oil filling tube I just bead blasted?? I was looking at options such as Duplicolor's Hight Temp Paint, POR 15 Hardnose Paint (could I just use rustoleum's primer if I wanted to use POR-15 black on the timing cover and filler tube or would I need their primer??) Now for the radiator,...what would you guys suggest?? Who makes a decent radiator paint,..or would POR-15's "rust preventitive paint" covered by their hardnose black paint work fine and not create a problem with the radiator dissipating the heat correctly?? Thanks in advance!!! Jason | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Jason, Use real radiator paint put on very thin, or nothing at all. It doesn't take much to hose up the heat transfer. Ask a radiator shop what to use.
As far as the other stuff, a high temp paint or engine enamel will be fine. I haven't used the POR hardnose stuff before but the regular stuff doesn't stick to bare metal very well.
Whatever you use make sure you get all the oil off before you paint. Oil pans can be hard to paint. Bead blasting doesn't get the oil out of the pores in the metal. I would recommend at least a 2 day long soak in a caustic solution or a good steam cleaning followed by a "metal prep" phosphoric acid wash to get the oil out. Red devil lye in a 5 gallon plastic bucket works well to remove all oil and grease from just about anything metal. You can leave it in there for weeks, just don't get any on your skin.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | On those parts I would suggest just any good rattle can paint. High temp is not really needed on those particular parts but it would not hurt I guess. I used black enamel from Wallymart. Has been fit for purpose so far. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | |
