8 members (Gdads51, LAROKE, Phak1, JW51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd),
86
Mod | | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I keep having connection problems on the 1 ton 1950. I took off the battery cables and cleaned the connection points. The starter was really gooey. I cleaned the battery posts, I cleaned the cables and then reattached them. Now, nothing and the foot stomper seems to stick. I replaced the spring with one off my parts truck and it still seems sticky. So my questions: 1. I swapped out the positive cable as the old one was pretty rough. Is it possible I have the wrong size? Looked the same. 2. Where does the ground strap attach to the engine/Tranny as mine was disconnected? I have since reconnected it. It worked turn over with it on or with it off.
If nothing else, the battery is fried... Afraid to boost until I know more. Thanks
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 6v or 12v electrical system? If 6v, the gauge of the battery cable/strap should be no smaller in diameter than 2 gauge. 1, 0, or 00 (2/0) gauge cable and ground strap are better Do not use a di-electric grease at connectors - use a conductive anti-oxidant grease such as these | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Passenger side bell housing. There are two bolts that hold on the foot starter assembly. One of them connects the strap then to the top frame rail right across from it. Should be a hole there to accommodate it. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks fellas. Battery is weak. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | So guess what?! It wasn't the battery's fault after all! Well... yes it did need to be replaced, but the fuel pump was jammed up. I tore into the fuel lines. Petcock on tank... Clean. What the? Hm, ok Fuel filter at tank....clean. What the? Hm, ok Fuel filter at carb...clean. What the? Hm, ok Fuel lines.... All clean. What the heck and beans? So I took off the fuel pump and whoa!!!! The rubber that was used to seal top lid had swelled terribly and was stopping the pump from sucking. No wonder the old girl would barely run! Changed the rubber and now along with the clean cables and new battery....Purrrrrrrr.
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Having two malfunctions at the same time is always the most "fun" to diagnose. Good find!
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | they usually run after i touch them | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | they usually run after i touch them Are you related to Carl? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Better check the oil for fuel. Don't want to mess up the bearings!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Could the fuel pump being backed up like that cause fuel to get into the pan? Would it push past and get in through the pump hole in the block? | | |
