0 members (), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
when I purchased my 1954 3100 it had no bed. While redoing the Suspension, I purchased an under frame spare tire carrier and it came with out the supports. I had some u channel and proceeded to construct the front and rear supports.
My first question is which frame holes are used for the front support as referenced in sect 10 sheet 2.00 of the assembly manual?
On my frame the support closest to the cab has 3 holes to choose from.
The manual on sect 2 sheet2 shows only 2 for the 3100.
Secondly does anyone have the rough hole locations for the strap bolts in the supports?
Drew
1954 3104 3 window
Drew,
Here are some photos of a 1954 Tire Carrier.
Maybe these will help you. I sold it so I cannot help with the ?? you asked.
Harold
Harold
Gas Pumper
Gas Pumper
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks deve your pic clearly shows center hole. Any idea on the strap bolt holes? It look to be around 7" +_
Drew
1954 3104 3 window
Gas Pumper
Gas Pumper
I am not familiar with a strap. What does that look like?
Deve
The Think Tank
the strap is the part painted in red on your picture
Drew
1954 3104 3 window
thanks for the photos
Drew
1954 3104 3 window
I think that is actually dependent on the size of the spare tire. Basically to center it in the carrier.
Gas Pumper
Gas Pumper
Yes. The size of the tire will determine the length and spacing. I am making a Hitch for a friend and he has a 52 with that same carrier. It has been a challenge to make it so that it works nicely with that carrier, but it worked out great. Personally, I am not real impressed with the 51-59 carrier. Seems kind of unwieldy and no good way to balance the tire on that thin rail when wrestling with getting it up there, but it is what it is.
Deve
The Think Tank
