6 members (Youngin' Tut 59, TPR57C, mason86, 32Fordpuchoptop, Oldcaliforniakid, Otto Skorzeny), 102 guests, and 1 robot.
Topics128,050
Posts1,055,683
#11644 05/06/2003 12:42 AM
pulling the bellhousing off my 235, i have discovered the p.o. has covered a factory hole in the rear of the engine, under the bellhousing, with a piece of sheet metal and some gasket sealer. what goes in this hole? seems to need some kind of freeze plug, although it is not in the water jacket area. does anyone have a part #.?
#11645 05/06/2003 1:21 AM
Phil,
Is it directly behind the camshaft? There is supposed to be an expansion plug about 1-3/4" diameter driven into the block directly behing the cam.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#11646 05/06/2003 2:01 AM
OlBlue's right. Measure the diameter, but I think 1-3/4 or 2". You need a cup shaped soft plug, you can get them at a parts store. While you have it apart, there is a freeze plug just below it, about the same size, and dish style. If it's brass, leave it in. I would replace the steel one.
Fred
52 3600
69 C-10
