2 members (Frank50, Joe H),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Discovered why I struggle with the choke on my 283. Appears that the choke cable holder is being pinched by the oil breather canister sitting on the top of the rochester 2B carb. The oil breather was a yard find. It is the correct size but not original. Might the original have had some sort of cut out at the bottom(?) Is there an carb extension I should be looking for? Has anyone dealt with this problem? Anyone look at the underside of their oil breather? http://s1377.photobucket.com/user/d...20151206_083618_602_zpsbjyhztg4.jpg.html | | |
