1 members (baldeagle),
45
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | how close should the replacement rocker panels and cab corners be when put into place? because, i put them both where the originals were...and there is a small gap between the 2. i know the door will cover it up, but...is it supposed to be that way?
thanks.
.later days. .desperado. .sam. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't expect the panels to fit "right out of the box". They will require a lot of fitting.
That said, what are you working on that the rocker panel and the cab corner panel are adjacent on? Seems like one should be inside the door jamb and the other outside. | | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | Cletis, yes, the door jamb is there. but when they curve down, like below the door, theres a space. is that right? if anyone would be so kind, would you take a picture of your cabrcorner/rocker panel area on a 67-72 truck? thanks!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, I don't have any "new" trucks so I can't see how it goes together. All mine are from the '50s. | | |
