1 members (baldeagle), 37 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#116415 06/07/2005 1:03 AM
how close should the replacement rocker panels and cab corners be when put into place? because, i put them both where the originals were...and there is a small gap between the 2. i know the door will cover it up, but...is it supposed to be that way?
thanks.
.later days.
.desperado.
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
#116416 06/07/2005 5:48 AM
Don't expect the panels to fit "right out of the box". They will require a lot of fitting.
That said, what are you working on that the rocker panel and the cab corner panel are adjacent on? Seems like one should be inside the door jamb and the other outside.
#116417 06/07/2005 5:16 PM
Cletis, yes, the door jamb is there. but when they curve down, like below the door, theres a space. is that right? if anyone would be so kind, would you take a picture of your cabrcorner/rocker panel area on a 67-72 truck? thanks!
.later days.
.desperado.
.sam.
19 and lovin' it.
.later days.
.sam.
#116418 06/08/2005 4:16 AM
OK, I don't have any "new" trucks so I can't see how it goes together. All mine are from the '50s.
