1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | Looking for one 15x 51/2 wheel with 6 lug any out there Looking for the ones that were on 1960's pickup Thanks keith | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | keithfielder With clips? W/O clips? delky dave in WY
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I just dug out my set of 5 wheels. They are correct for my 1965 and have the 3 bumps and no clips. Shipping might be high. I no longer need them. They need to be media blasted. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Clips til about 63, then nubs in 64 up.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | keithfielder--So, are you searching for one with clips or without clips?? delky
| | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | Without clips ,just nubs Thanks,keith | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I have a 5"...seems like all the other stock rims I've had are 6".
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
