9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
My 57 3800 is DRW, I would like to change to SRW. I know where I can get some front hubs from a 3/4 ton. Are they the same as 1 ton? Will I need any other parts from the donor truck besides the hubs to make the change on the front? Thanks.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
My research shows 53-59 uses same front wheel bearings and therefore hubs should interchange.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=888231
I'm not sure if brake drums are different for front of a 1 ton single or dual to know if you can reuse yours? I'm sure they're larger than 3/4 ton drums.
Have you investigated in the parts book?
http://chevy.oldcarmanualproject.com/1929_57chevyparts/index.htm
1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Dusty53
