4 members (Otto Skorzeny, 1955 1 Series, JW51, 1 invisible), 75 guests, and 2 robots.
Topics128,037
Posts1,055,582
#1163937 05/05/2016 1:45 PM
Are all 216 flywheels the same? And would there be a different clutch size for a truck engine than a car engine. If all the flywheels are the same, will they accept different clutches?
I am trying to get ahead of the game on my engine replacement. Usually a bad idea for me.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1163952 05/05/2016 3:05 PM
There were at least 2 different size clutch discs used with 216 engines.
The flywheel used one clutch size.
A car could be ordered with a 216 and a larger truck-type flywheel/clutch-disc (same flywheels and clutch discs - cars and trucks).
If I am wrong, we'll hear about it.
Here is info for 1946 and 1952 (as examples):
http://chevy.oldcarmanualproject.com/chevyresto/52037.html
http://chevy.oldcarmanualproject.com/chevyresto/52151.html
http://chevy.oldcarmanualproject.com/chevyresto/4639.htm
http://chevy.oldcarmanualproject.com/chevyresto/4688.htm
MikeE #1163957 05/05/2016 3:41 PM
1937-39 use 4 mounting bolts.
1940-41 use 6, 3/8" mounting bolts.
1942 and later use 6, 7/16" mounting bolts, and smaller center pilot hole.
My Blog
MikeE #1164225 05/07/2016 6:33 AM
I want to say a 1 ton flywheel/ clutch had a different bolt pattern (flywheel to pressure plate) than 1/2 ton. I used a 216 flywheel from a 1 ton on my 235 (so I could keep stomp start; 139 vs 168 tooth, not 1 vs 1/2 ton) that I put in my '49 1/2 ton and I think I had to use a matching 1 ton clutch set. I believe the 1 ton flywheel was thicker, too.
MikeE #1164237 05/07/2016 12:37 PM
"I want to say a 1 ton flywheel/ clutch had a different bolt pattern (flywheel to pressure plate) than 1/2 ton."
49Neo,
That is correct for all/many years (clutch sizes).
That is shown at the links for truck clutches that I posted above.
It is shown here for 1949 trucks.
"I believe the 1 ton flywheel was thicker, too."
It would be interesting to know if the thickness of the flywheel is different. That is possible as far as installation is concerned.
