4 members (MikeE, Otto Skorzeny, Cosmo, Wayne67vert), 123 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1163664 05/03/2016 7:26 PM
I recently bought a 51 Chevy 3800 flatbed dually, knowing it needed brake work. What I didn't know was how hard it would be to find brake shoes for it.
It doesn't help I am very new to all of this. From searching the forum I've seen that I probably have a pre Huck brake system.
Where would be a good starting point to find shoes for the front brakes? The local parts store is not looking like a reliable source. Or should I just try to have them relined? And where would be someplace that would do that for me?
Big Bolt Forum Moderator
I would just have them relined. That is what I will be doing with my 2-ton.
Mike
1 Offline
Check with a brake and clutch outfit that works with heavy truck parts. In Seattle where I live that's Brake and Clutch Supply. They've relined assorted brake shoes, e-brake bands, clutches etc. for me for big and small trucks.
1951 3800 1-ton
In the DITY Gallery
Brake drums for a 3800 are just about nonexistent, so don't have them machined at all unless it's absolutely necessary, and then only do the bare minimum of cutting.
Not sure if this is applicable or not but a tech article written by Bob Adler concludes that these rigs benefit from FF pads
1946 GMC Project
"Back-in-the-day Restore"
Crusing in the Passing Lane
Don't break your neck repairing your existing rear end, lots of modern rears will work and have parts available.
Ed
Yes, depending on your goals for restoration and or use you may consider a "14 bolt" rear axle swap. Several threads exist on the subject.
There has been some discussion about swapping modern brakes from a 14 bolt to the old Eaton axle. I'm not sure if it's dead simple or just possible with some work...
This could be an intermediate swap if you want the old axle but can't find or don't want the old brakes.
1952 Chevrolet 3800 pickup
---All pictures---
I found a place that can send them in and get them relined. I am thinking of just going that route because the only place I found with shoes are on back order.
I've thought about upgrading to disc brakes, but it's way out of my expertise and ability of my garage I believe.
To be honest, I just want to haul some rock and be able to stop. All while driving something that looks really cool.
Welcome to the Stovebolt. I am sure you will enjoy this site. I had my 1 Ton shoes relined and they work perfectly. Now I don't haul loads so I can't comment on that.
1951 1 Ton Completed
If your drums are good reliningyour original would be simplest and most cost effective.
If your drums are not good again look at swapping newer DRUM brakes from a 14 bolt.
You could swap disc... but that's more trouble because you then need to swap master cylinder and install front disc.
---All pictures---
The drums are in great shape. I'm just going to try and have them relined.
Thank you for the info and help. I'll post how it all turns out.
This thread has some dicsussion about swapping modern drum brakes on the old Eaton axle.
http://67-72chevytrucks.com/vboard/showthread.php?t=536119
I have not read the whole thing but one question unanswered as far as I did read is what width brakes are they using? There are 3.5" wide and some narrower, and also different drum diameters on the various 14 bolt axles. Perhaps on a later page of that discussion they actually give part numbers or specifications.
Point is it is possible to upgrade to modern and available drum brakes at very little cost.
---All pictures---
Moderated by  Dusty53
