1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Does the engine need to be running when bleeding the brake system on a '56 C6500 equipped with a bendix hydrovac system since the master cylinder pushes fluid into the hydrovac? I recently replaced my master cylinder and some brake lines. The brakes felt hard after I bled them without the engine running but when I drove the truck I had to pump the heck out them to get them to work. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Engine can be running but vacuum should be disconnected first. Google 'Precision Rebuilders' ,look at their catalogue and manual, print out appropriate pages.
Ed
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I rebuilt the rear wheel cylinders in my 1958 6400, then tried to bleed and could never get a good pedal. After I rebuilt tha master cylinder, replaced all the lines (steel and rubber)and rebuilt the front wheel cylinders (pistons in the fronts were frozen) I bled it again and now have good brakes. (home-made power bleeder and engine off). All that said, make sure everything is in good shape or it may suck air in.
Also, make sure you adjust the top shoe on the rear brakes properly for bleeding (loosen it all the way up so it collapses the piston all the way into the wheel cylinder and keeps it from creating a pocket that can trap air.) | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | I read in shop manual: Bleed the slave cylinder in the hydrovac first Then the upper bleeder of the hydrovac Next comeslower brake cylinder furthest from hydrovac Then upper of same wheel Work your way closer to hydrovac lower cylinders first as applicable.
I did this on mine, starting with a dry master and hydrovac and even a couple of empty lines (replaced) and it worked like a charm. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | A pressure bleeder will make life so much easier and will improve relations with your wife who may not like sitting in the hot/cold cab playing the up-down game with the brake pedal. But whatever you do, check the fluid level in the master cylinder OFTEN or you will have to start over. That little sucking sound from the master is such a downer. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Try a search - I think other people have posted how they easily fabricated a pressure bleeder and master-cylinder cover/cap/connector. | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | I saw how several people built them from a pump sprayer. I am going borrow the wife's and add a female 1/8 air fitting at the air gauge to connect to a pancake compressor set to 50 psi.
My big concern is safety. Precisionbuilders recommends 50-60 psi and the Motive unit recommends 15 psi.
I will use a long air line with the tank sitting in a garbage can the first time to see if it will take 60 psi.
