1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Are all 216 flywheels the same? And would there be a different clutch size for a truck engine than a car engine. If all the flywheels are the same, will they accept different clutches?
I am trying to get ahead of the game on my engine replacement. Usually a bad idea for me.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-39 use 4 mounting bolts. 1940-41 use 6, 3/8" mounting bolts. 1942 and later use 6, 7/16" mounting bolts, and smaller center pilot hole.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 36 | I want to say a 1 ton flywheel/ clutch had a different bolt pattern (flywheel to pressure plate) than 1/2 ton. I used a 216 flywheel from a 1 ton on my 235 (so I could keep stomp start; 139 vs 168 tooth, not 1 vs 1/2 ton) that I put in my '49 1/2 ton and I think I had to use a matching 1 ton clutch set. I believe the 1 ton flywheel was thicker, too. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "I want to say a 1 ton flywheel/ clutch had a different bolt pattern (flywheel to pressure plate) than 1/2 ton."49Neo, That is correct for all/many years (clutch sizes). That is shown at the links for truck clutches that I posted above. It is shown here for 1949 trucks. "I believe the 1 ton flywheel was thicker, too."It would be interesting to know if the thickness of the flywheel is different. That is possible as far as installation is concerned. | | |
