6 members (3800GUY, David Bush, Oswald, Wally / Montana, Rusty Heaps, 1 invisible), 34 guests, and 2 robots.
Topics128,074
Posts1,055,911
Members48,429
#1163582 05/03/2016 4:01 AM
Concidering including A/C in my project 1/2 ton 53 chevy. going to run 235 twin webbers blah blah blah, alum radiator electric fan no P/S, altinator. will I have to run a double pully? has anyone done this? how did you like it? The interior kit doesn't look too bad. keeping stock look, kinda.
I put AC in my stock 51, 228 six cyl. Now has alternator and 12 volt, which you have to do for the A C . It does OK, but gets a little warm if stop and go travel.
My unit does not have a double pulley.
48 2 ton has dual W-1's on an Offenhouser manifold and Fenton headers on the 235. Powermaster alt.
Mounted A/C on drivers side and used stock type single belt (wide).
Major engineering project because of manifold and header clearance problems. A lot of modification to the mounting brackets and had to modify inner fender for it to fit, and add an idler pulley.
Works fine.
The Vintage Air bracket that I used had 1 belt for the crank pulley, water pump and a/c compressor. The a/c compressor had a double pulley that ran to the alternator. A/C compressor is mounted where the generator originally was installed. The alternator sits above the compressor about even with the head.
Here is a link to a photo:
http://i231.photobucket.com/albums/...xe%20Powerglide/DSC_2642_zps8de914c9.jpg
Moderated by  ndkid275, Phak1
