4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
What is used to cover the top portion of the drivers side kick plate just above the steering column, brake and clutch peddles. Is it a metal piece or just a felt piece.
It's a 41 1 1/2 ton
Sometimes you're the window
Sometimes you're the bug
It's both..a small metal frame arrangement with a felt insert that fits around the column & pedals. need to charge camera battery, but can send photo if you want one
Darwin
Moderated by  ndkid275, Phak1
