3 members (tclederman, TUTS 59, 1 invisible), 132 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
What is the exact diameter of the bolts that hold the side cover on, also, what length should they be?
Oh yeah, do I use a flat or lock washer?
Engine is a 51 216.
thanks.
The original bolts are 1/4-20, by about 3/4". They had what is called a Pan head screw, shown in this link. They had a star washer attached in most years, although I have seen split washers attached on some years.
I always include a flat washer to spread the load out farther.
My Blog
1/4x20 pan head screw - the classic stove bolt
Please don't be angry but I'm nitpicking here.
I'm an old aircraft wrench and and putting a flat washer between the lock washer and the metal you are attaching the fastener to is a no-no. The lock washer is suppose to bite into the metal of the fastener and the metal. If it bites into the flat washer and the flat washer turns the the lock washer and fastener will also turn.
Too funny!
Vibrating loose on a side cover has never been much of a problem.
I prefer to limit leaks over any backing off in this case.
My Blog
Crusing in the Passing Lane
I usually insert some RTV silicone to keep such bolts tight, and not over tighten.
Ed
Ok thanks everyone for the replies.
Brad.
Gas Pumper
Gas Pumper
The idea of the flat washer in this particular case is how the non-reinforced hole tends to concave and then cause sealing issues from overtightening. Same reason we put reinforcing plates on valve covers. This principle works for most thin sheet metal on the engine. The oil pan also benefits from a flat washer on each of the 18 bolts for the same reason. Since we use gasket sealer on the gasket and the bolts, there is very little worry about them backing out.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I am with Beltfed on the flat washer deal, but only if you plan on flying an airplane with your Stovebolt engine! smile
On land, a tuned up Stovebolt doesn't vibrate enough to tell that it is running at idle, let alone vibrate a side cover bolt loose.
BTW, I can only hope that someone who goes by the name of "Beltfed" has a good sense of humor, and realizes I'm just pulling his leg a little.
Carl
I get it. Guys will do all sort of things to get around problems caused by themselves or PO's. Done it myself. I would however caution guys to pay more attention when a fastener is being used in a critical area like suspension, steering, etc. This would include things like using a grade 5 fastener in a grade 8 application.
"Beltfeds" are a class of firearms (machine gun) that use a belt to feed the gun ammo. My government let me borrow one to waste many thousand of dollars of ammo out the door of a Huey once upon a time. I now collect them as a second hobby, hence my handle.
When are star washers preferred over split washers? And vice versa.
