0 members (), 389 guests, and 8 robots.
Topics128,159
Posts1,057,039
Members48,460
#116322 02/05/2002 1:03 AM
Junior Member
Junior Member
Anyone out there have any experience with replacing the bed to sidewall strip. I want to replace the origional steel angle strips on my "59" with a stainless steel ones. Mine are corroded and trapping stuff from back in 59.
they're spot welded in about twenty places and bolted in two places. I centerpunched each weld and picked up a spot weld drill bit from Eastwood. I intend to substitute "some" bolts for welds.Any cautions and or recommendations on this before I cut?
#116323 02/06/2002 7:12 PM
No problems just as long as you realize you only have to go through the top piece of metal. If you do go through both it's not a big deal to weld up the hole, just more work. You'll find that using a "spot weld drill bit" won't leave a smooth surface anyway, some sanding (light grinding)will more than likely be required after you remove the angle stip.
#116324 02/07/2002 2:55 AM
Red dot, center of chest ...
Fatfenders, what do you mean by "the top piece of metal"? I've been wondering about this myself. I want to use stainless, but I figured the spot welding would discolor the metal. How do you spot weld stainless without marring its appearance?
And what's the best way to remove the old strips? With the spot weld bit that msteuer mentions?
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#116325 02/07/2002 3:53 AM
Anonymous
Unregistered
Anonymous
Unregistered
Baldy,
The spot weld drill (or cutter) just cuts through the top layer of metal if you do it right. If properly centered on the spot weld, it basically removes all the welded material and then nothing is left holding the two pieces of metal together.
Weld stainless with stainless rod/wire or with a TIG welder with stainless filler if required. Grind/polish the weld smooth and there will be no discoloration - it is "stainless" grin
#116326 02/07/2002 4:16 AM
Ken, couldn't you plug weld from the back with regular MIG wire? I know that you can weld to the stainless, so just as long as you didn't get real good penitration, you would be all right, I think.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#116327 02/07/2002 5:12 AM
Thanks guys. That isn't something I can do myself, but now that I know it can be done with marring the stainless, I'll find someone who can do that for me. Should you paint the box before welding the stainless on?
Paul Schmehl CI 6
geek@stovebolt.com
#116328 02/07/2002 5:16 AM
When it comes time to install mine I will use some carriage bolts to install the new ones. Only about two of them will be visible. The rest is obscured by the fender.
54 3100 with 235
62 flatbed dump C60 with 261
