1 members (klhansen),
149
Mod | | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Thinking of taking on a basket case '40 half ton project. (Like I need another project) I'd rather keep the solid axle rather than put in an IFS. I have found kits for adding a sway bar, tubular shocks and disc brakes with the after market vendors. I'd like to come up with leaf springs that would ride about an inch lower but have a good progressive rate that would stiffen up quickly when compressed. Also I'd like come up with a good steering box swap that would work well with the original axle, but with a quicker ratio, and maybe even intregal power steering. Anyone else been down this road?
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Joe: Sorry but I don't have an answer for you, but I would like to know where you found a sway bar for your 40. I'm thinking about putting one on my 46 but all I've seen is for 47 and newer. Where should I look? Thanks George | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | My 37 truck is similar,I used monoleafs on the front, disc brakes and a steering box from a 41-47 GM truck.I have a Patrick's sway bar on my 51, looks like it'll fit the 37 with a little work. The 41-47 box isn't exactly fast ratio or power, but it's a nice bolt in upgrade and the monoleafs lowered the truck about an inch and a half.I did add 2 of the longer leaves from the stock springs leaves to the mono leaves, I felt they were too cushy. The disc brake kit was easy to do, that was 7 years ago, the kits now are better engineered.The truck has manual discs, in my opinion, power discs are overkill on the light truck. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | My mistake George. I was looking in the wrong catolog on the sway bar. I guess it's back to the drawing board on that.
Tony, did you have the mono-leaves built at a spring shop or swap them from another vehicle? I may not need a quicker ratio in the steering gear, but I definitly want to tighten things up. What I hope to do is improve brakes and handling enough that 75mph on the Interstate is not white knuckle, but avoid doing a front clip or aftermarket IFS if possible.
Joe McNeel
