9 members (Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51),
83
Mod | | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Its popping out of the track closest to the front of the truck-it start coming out near the bottom of the groove (on the way up). I put new wiskers in and the glass seems to fit pretty tight. It appears that I could maybe shim out the U TRACK style wiskers at the bottom to keep the glass more into the grooves, or attach a thin plate to the bottom of that track where it tends to come out. IDEAS????? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've had this problem several times on different cars. I'm just acting questions here. Is it a "smokers" type window where the window kind of tilts as it goes up to allow a crack to stay toward the top front to allow smoke to excape, as on a mid thirties Ford truck. Also there should be two wheels or rollers that are in a groove below the glass. Is one of the 'popping out of the groove? Another problem I've had is one of the channels had broken or separated from it mounting point on the door. This will let the channel 'twist'. I would open up the door on the other window and try to figure out where the two are different. Good luck.
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I did use a mix of parts.........but the channel is brand new. I have two more regulators- any way to tell if what I have on is a smoker? It does appear to not go up evenly. I have not installed the new track on the other side yet- planned to get this one done first. Now maybe I will to see how it works? George
THe wheels are staying on the regulator- it just pops out of the track at the front/lower track. I shimmed out the track some and that helped. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | A smoker window will not have the vent window in front of it. The track/regulator allows (as you lower the window) the window to drop down at the top front first. Can to hang a plumb bob from you channels to the section that holds the bottom of the window to see if they are plumb? Mix of parts? What mix? Is the front roller allowing the window to go down below the track? Is the bottom of the widow, when rolled down, parallel to the floor? Do you have the right piece of glass and is the top cut correctly? I'm not there so maybe silly questions.
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | No vent window. The mix of parts is the handle/latch, the door, and regulator- they all came off different trucks.The glass was cut new and fit perfectly inside the factory window frame. I just tried it a few more times and it seems better I shimmed out the front track about mid way up with some stiff foam and the glass stays in. I may even attach a thin piece of sheet metal in the area to extend the actual track out maybe another inch. I'll do that BEFORE I attach the door covers. Will be driving it to the monthly cruise in tomorrow night- actually the first time I've had it out. George
check out the picture of my truck in the link just under my user name on this post. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Assuming the regulator assembly is working correctly ( raising glass evenly both sides ), it sounds like your window track is either worn out or shifted out of place. You can purchase new, flexible track that is pretty easy to install - fairly deep channel ( 3/4" ?? ). As I recall, there are metal tabs in the window opening that help locate the track to keep it tight on the edge of the glass. | | |
