0 members (),
130
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Just installed my new accelerator pedal on my 1949 Chevrolet 3100 1/2 ton truck with 216 cu.in. engine. The pedal is approximately 1" from the floor when released and seems to go to full throttle. How far away from the floor should the pedal be when released? Doesn't seem to have much throttle travel? Had to bend the rod slightly so that it would not bind on the hole through the floor board. Any ideas or suggestions?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | The pedal on my "49 is approx. 2-1/2" from the floor mat to the surface of the pedal when measured at the top of the pedal.
Ed
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Fixy, are you sure that you can achieve full throttle with only one inch of pedal travel? Are you using the original bell crank and have it installed correctly? (I don't know if it is possible to instal it wrong.) Something isn't right. Carl
