| | | Forums66 Topics128,078 Posts1,056,054 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 13 | I put in an LMC 2-speed wiper motor kit to replace vacuum one. Hot wire to wiper power,fused at fuse block.No action! Just a bad ground (to dash brace)? Fuses a are good, 15 amp (one inline,LMC) and one at fuse block.Obviously I am electrically challenged. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  It really helps if you ID your truck year and model at the start of every post, we cover over 60 years here and they are not all wired the same. Do you have power and ground at the motor? Do you have a multi meter and/or test light? Mike B  | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Wire per instructions in kit. How many wires are there? IF the motor in your kit is supposed to be grounded by bolting, add a ground wire from motor to a good ground.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Mine(52 1/2 ton) came with a ground wire on the motor case. 2 speed, self parking and worked fine(Classic Industries). Inline fuse included. Work fine but the collar on the drive tends to slip(winter ice did that). You can hook to the battery for a simple test, but you need to understand the switch for good results. Multiple wires on the motor, Slow, Fast and park(through a cam operated switch inside the motor). Can be confusing. Should have a diagram for install.
Steve H
| | | | | Joined: Apr 2016 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 13 | Sorry I am so late returning. Truck is a 52 Chevy, 12 volt. I do have a voltage tester. Ground wire from motor attached to same spot (dash brace) as support bracket for motor.
Steve H
