5 members (Otto Skorzeny, Woogeroo, klhansen, 2-Ton, TUTS 59), 77 guests, and 6 robots.
Topics128,193
Posts1,057,241
Members48,465
Anybody ever change these bushing out? looks like a real [censored].... whats the best way to get them out of the hangers? mine are egg shaped.....Heat? Ball joint removal tool? These are threaded bushings that the hanger bolts screw into
If your hanger pin is threaded with a grease fitting on the outboard side and you have a hole lined up through the truck frame, here's what I do to remove the pressed in bushing.
Take the grease fitting out of the pin.
Un-screw the pin from the bushing.
Turn the pin around and screw it back in until there is only about 3/4" showing. This is done so you're hitting the solid end of the pin, not the drilled hollow end.
Using a 8 pound sledge hammer take about a 18" swing and hit the pin dead square head on. As the bushing moves in, screw the pin out for another hit and re-peat until you've driven it out through the hole in the frame.
Sometimes a little heat on the cast hanger bracket helps...
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike sounds like a winner.....also I liked your story on the 56 3100. Im in a similar situation with this truck. My 30 year old son is working with me on this project. He has two small kids ao is able to help 1 day a week. We are building a resto/rat rod with an LS motor I also restored a 1957 Belair 2dr HT in the 80's
Thanks, my son was able to help with some of the two man parts, but for the most part I was on my own...glad it's done. Now I'm off to the next project, the '56 Brush Truck...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
