1 members (Tiny), 304 guests, and 2 robots.
Topics128,162
Posts1,057,068
Members48,463
I'm looking for some details and differences in the various 48-54 GMC maintenance manuals, particularly the wiring diagrams, if any difference.
I have what I thought was the right manual for my 51, it's a reprint (was listed as an original when I bought it) and "covers" 47-54 and models 100-400.
This is not where I bought it but it is the same manual
http://www.faxonautoliterature.com/...00-Repair-Shop-Manual-Reprint-P9815.aspx
They describe the manual:
Quote
This is the book GMC originally used to repair 1953 and 1954 models. It can be helpful for 1947-1952 models also
In my searching I see that GMC did offer a manual to cover the 1951/52 model trucks size 100-350, this is the exact manual that covers my particular GMC.
Here is a reprint, originals can also be found, they have "X-5111" in the upper right corner of the cover.
http://www.faxonautoliterature.com/...k-Repair-Shop-Manual-Reprint-P25248.aspx
I'll probably find and buy one of these originals in time.
Until then does anyone have this GMC 1951-1952 only manual and can you show me the wiring diagrams so I can compare to the diagrams in the 1953-1954 manual (the manual now sold as 47-54)?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
There are no GMC Maintenance (Shop) Manuals at either of the links above. If I am incorrect, please post a link to a specific manual.
As Grigg posted, the "reproduction" GMC manuals are often multi-year, and the 1954/55 (Z-series) GMC wiring might be a little different, due to different dash. However, the type of gauges did not change, just the style and location of gauges. The GMC and Chevrolet Truck gauges were not at all similar in 1954/1955st trucks.
There is only a 55-59 GMC small truck Maintenance Manual at Keith Hardy's OLD ONLINE CHEVY MANUALS (no separate GMC wiring diagrams).
http://chevy.oldcarmanualproject.com/gmc/5559mm/index.html
How do you find the bold pattern of a 1954 chev 3/4 ton with 16 in wheels?
I have a 1954 3/4 on factory flatbed with a 4 speed with granny low. Cab needs some body work. It's just a shell. no glass. motor, trans and rear are all there and working. Recently overhauled and all new brakes. It is all original. It has the gauges and I bought a Painless Wire harness for it Got good gas tank behind seat. No original seat. I got 2 black leather power seats that will work well. First time doing something like this. I think I took on too much with this project.
Daniel,
You should post a new/different question as a New Topic (with a new title).
If GMC 3/4 ton was the same as 1954 Chevrolet, look at the various 3600 wheel specs.
How many bolt holes on your wheels? 8 bolts in a 6.5" circle?
6.50x16" with 5.50" rim width and 4 9/16" rear offset?
I think I found my manual on e-bay. I think. It was like yours. Went through several year models.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
http://chevy.oldcarmanualproject.com/chevyresto/54159.htm
In the future, you might want to post/start a new/separate topic, when you have a question not related to the original post in a thread.
Back to manuals,
If anyone has one of the earlier GMC manuals with X-5111 in the corner of the cover I'd like to see pictures/scans of the wiring diagrams.
I'm not really expecting any significant differences compared to the 53/54 wiring diagrams but I'd like to look and see just for my own curiosity.
Grigg
---All pictures---
I just ordered some original/used manuals.
A small 1951 GMC operators manual that should have a wiring diagram in it though not sure how detailed, hopefully fully.
Also a 1949 GMC maintenance manual, I can then at least compare the 49 diagram to the reprinted 53/54 diagram, and if no difference then likely 51 is also no difference.
In time I'll find a 51 maintenance manual at a better price. I do like old books and manuals...
---All pictures---
I have never seen an operators manual with a wiring diagram.
Me either, but the few pictures of it on eBay showed one, 1951 GMC...
I'll know more when it shows up.
PIC. 1
PIC. 2
Grigg
---All pictures---
I've collected, scanned, cropped and edited for clarity, and noted the printing date on the various GMC wiring diagrams.
They are pretty large clear images and should print well.
They can all be found in this album
https://goo.gl/photos/H26qPfBHb7eS15698
Here is the 1951 GMC diagram from the owners manual.
https://goo.gl/photos/UvtdEAKaUC6EATES9
To answer the original question:
The 1951 conventional truck wiring diagram is the same info as on the 1953 diagram. The 1953 diagram however includes more info for the optional hydromatic, optional electric wipers, and optional electric two speed axle.
The 1951 and 1953 COE wiring diagrams I believe are exactly the same, no changes/additions.
The 1949 diagram is drawn in a different configuration and hard to compare, though it obviously functions about the same I suspect there might be a few connection details/differences. The wire color code is a legend on a separate page. I believe there are some differences in the color code for the same wire function between the 1949 and 1953 diagrams.
Grigg
---All pictures---
