0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | ok i am new to this body work thing, i need info and help. i got my panel 3 weeks ago and after a 28 year Nap, she is back up and running, i have the gas tank out now and would like to replace the rust-out under the filler neck of the gas tank,the section right above the running boards it's a section about 28" long by about 6 " wide in the curved section....i have tried to find a patch panel --but no luck is this something i will have to have made...or find in a junkyard and cut out(i have not found good section on an old one to cut out)........if anyone know where i can buy this PLEASE LET ME KNOW-------thanks
1950 Chevy Panel 310
| | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Not to familiar with panels, but it sounds like you may be able to start with an outer door patch panel and fit it. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | flintriver,
Zeke has got it right. Here is an extract from a technical article on Jim Carter's website (it is not easy to give a direct link):
"Suburban/Panel Truck Body Rust Repairs
Replacing major rust-out between the rear fender and door of the 1947-55 Suburban or panel truck can be easier than you think. The curvature in this area is the same shape as the adjacent door.
Therefore, locate a 1947-55 donor door of limited value due to butchered radio speaker holes or a badly rusted bottom. Remove the outer panel. It has the correct metal gauge and round shape as the Suburban and panel truck body."
Other difficult spots on a panel/suburban are behind the rear wheels and the rear sill.
Good luick, Tim | | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | patch panels aint that bad I've replaced 2 and got 2 many more to mention they pretty much fit with a little umph from the installer(namely me) | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | I've done this repair on both sides of my '49. I took a flat piece of sheet metal, cut it to the measured length/width, and bent it by hand to fit. this made a virtually invisible repair.
JS | | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | tclederman--------now i am looking for a donor door for the patch.........just one more reason to go to the JUNKYARD..............yes!!!!!!!!
| | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | i pulled the original floormat out last night , had some rusted out holes in the floor board that had had a patch or three............now what?????
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | No need for a junk yard. M.T. has the patches  | | |
