5 members (Tronman, klhansen, EchoBravoSierra, Otto Skorzeny, 3B), 73 guests, and 2 robots.
Topics128,041
Posts1,055,490
Members48,424
Junior Member
Junior Member
ok i am new to this body work thing, i need info and help. i got my panel 3 weeks ago and after a 28 year Nap, she is back up and running, i have the gas tank out now and would like to replace the rust-out under the filler neck of the gas tank,the section right above the running boards it's a section about 28" long by about 6 " wide in the curved section....i have tried to find a patch panel --but no luck is this something i will have to have made...or find in a junkyard and cut out(i have not found good section on an old one to cut out)........if anyone know where i can buy this PLEASE LET ME KNOW-------thanks
1950 Chevy Panel 310
Z
Z Offline
Not to familiar with panels, but it sounds like you may be able to start with an outer door patch panel and fit it. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
flintriver,
Zeke has got it right. Here is an extract from a technical article on Jim Carter's website (it is not easy to give a direct link):
"Suburban/Panel Truck Body Rust Repairs
Replacing major rust-out between the rear fender and door of the 1947-55 Suburban or panel truck can be easier than you think. The curvature in this area is the same shape as the adjacent door.
Therefore, locate a 1947-55 donor door of limited value due to butchered radio speaker holes or a badly rusted bottom. Remove the outer panel. It has the correct metal gauge and round shape as the Suburban and panel truck body."
Other difficult spots on a panel/suburban are behind the rear wheels and the rear sill.
Good luick,
Tim
patch panels aint that bad I've replaced 2 and got 2 many more to mention they pretty much fit with a little umph from the installer(namely me)
I've done this repair on both sides of my '49. I took a flat piece of sheet metal, cut it to the measured length/width, and bent it by hand to fit.
this made a virtually invisible repair.
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
Junior Member
Junior Member
tclederman--------now i am looking for a donor door for the patch.........just one more reason to go to the JUNKYARD..............yes!!!!!!!!
Junior Member
Junior Member
i pulled the original floormat out last night , had some rusted out holes in the floor board that had had a patch or three............now what?????
Anonymous
Unregistered
Anonymous
Unregistered
No need for a junk yard.
M.T. has the patches wink
