| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | I'm having some trouble locating a source for brake parts for my 1946 3600, 3/4 ton. Wheels have 8 lugs which makes it more difficult to find the right parts. Any ideas? Mostly I need drums and cylinders. Thanks!
1946 Chevy 3600 Pickup 1948 Chevy Sport Coupe Country Club 1963 Corvair Monza Spyder Convertible
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Check with Jim Carter Truck Parts 1-800-862-3749 or eBay. Harold Brake Drum
Harold Is a restoration ever finished? | | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | No dice, checked Jim Carter, Filling Station and Chevs of the 40s. - the 8 lugs is the killer. Any other ideas?
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I'm missing something! In your first post, you said you needed 8 lug drum. The link I sent you is an 8 lug drum from J.C. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | The listing you sent is for a product that is not current. As of this posting, the JC model MEB126 does not come up in their current catalog not does your link load fully. Too bad, because it would have at least solved the issue for the rear drums. Thanks anyway.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I plug that into their online catalog, it comes up with the description and says they are in stock and ready to ship for $149 each. | | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | Thank you Harold46 and truckernix, I called JC and they do in fact have the MEB126. So strange that it does not always come up in the catalog. Well that takes care of the rear drums but it is the fronts that I am most interested in finding. The search continues, let me know if you have any ideas for finding an 8 lug front drum set. Thanks!
