| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Restored a 52 Chevy 3100 from the frame up. The body shop painted it with the original color and clear-coated it. What non-abrasive polish/wax would be good to put on it? Thanks. Bob | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Depending on the product they used, you may need to leave it alone for a month or longer to cure. I would ask the shop if you need to wait and also ask them if they have any recommendations for that particular product. | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | My recommendation is not put anything on it. The new modern clears are very UV stable and hold a great shine. Make sure you keep it as clean as possible, lots of sudsy water when washing with micro fiber cloths for drying. A very good detail spray to finish it up is all you'll ever need.
The minute you start rubbing it, your putting swirls in it. The less you touch it, the better off it will be.
