Brrrr
place holder
0 members (), 75 guests, and 1 robot.
Topics128,274
Posts1,058,431
Members48,489
Just received the new bumpers for my 49 AD and noticed that the rear has five punched holes. The center hole isn't needed. Obviously I could just put another bumper bolt in it but I'm looking for ideas, a small bowtie emblem? Suggestions are welcome.
If you plan on chroming, the chrome shop will do the repair. If you plan on painting, you can weld and grind smooth prior to painting.
My original '50 has that hole too, not sure what it was for.
Paint & Body Shop moderator
My '50 has the same hole. Please see the below link from Jim Carter's for information about the fifth bolt hole. And the rare filler bolt that can be installed in the hole.
http://www.oldchevytrucks.com/cgi/htmlos.exe/002310.2.1917951597600010861
I have been trying to locate
one of those filler bolts for thirteen years. I guess I will have to get used to the hole.
I got one of those filler "plugs" on a used bumper. As stated on Jim Carter's site, the post is not threaded; the "bolt" is held on with a spring nut. The head of the bolt has the stainless cover but the diameter of the head is a little smaller than the threaded bumper bolts.
Tim
