| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | I have a 37 GMC 1/2 ton with a Olds 230. I believe the correct engine color is olive (correct me if I'm wrong). Do I paint the bell housing and trans the same color as the engine or should they be cast color? The tourque tube and rear end I believe should be black. What is a good paint type to use on the engine.
Mike J 37 GMC
| | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | Can't help you on your engine color, but I can tell you that Eastwood\'s engine paint is good, and so is Napa's (the rattle can stuff you buy at your local Napa store). Ed | | |
