3 members (Otto Skorzeny, klhansen, 1 invisible), 66 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#116180 01/22/2002 2:22 PM
I have a 37 GMC 1/2 ton with a Olds 230. I believe the correct engine color is olive (correct me if I'm wrong). Do I paint the bell housing and trans the same color as the engine or should they be cast color? The tourque tube and rear end I believe should be black. What is a good paint type to use on the engine.
Mike J 37 GMC
#116181 01/23/2002 7:54 PM
Can't help you on your engine color, but I can tell you that Eastwood\'s engine paint is good, and so is Napa's (the rattle can stuff you buy at your local Napa store).
Ed
