8 members (Gdads51, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, Ponchogl, sron48, 1 invisible),
74
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | I have a 1952 that I think still has the original front end, however it looks like the PO shaved 3 lugs off. Looks like the front had eight lugs... I was under the impression that 3100's had 6 lugs? I am counting eight with the five and three shaved off can anyone shed some light on this for me, thanks
1952 Chevy 3100 AD 1964 Ford Bronco 2006 Dodge 2500
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If there is a metal ID tag on the cab between the driver's door hinges, post that code.
Photos in earlier posts look like a 3100, but there is no side shot of the bed (the 3600 bed is longer than the 3100 bed).
6 lugs on 3100 wheels and 8 lugs on 3600 wheels. Do front and rear wheels have 8 lugs?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are three rivets that hold the brake drum on that are often shaved off so aftermarket wheels will fit. Could you be seeing this?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | If there is a metal ID tag on the cab between the driver's door hinges, post that code.
6 lugs on 3100 wheels and 8 lugs on 3600 wheels. Do front and rear wheels have 8 lugs? The rear was swamped out with a 1968 chevelle, it has five
| | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | There are three rivets that hold the brake drum on that are often shaved off so aftermarket wheels will fit. Could you be seeing this? I think you are right......still strange that it only has five, I guess the front end could have been changed as well
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like the PO swapped out the front hubs for '49-'54 Passenger hubs to convert it to 5 lug to match the rear.
Bill Burmeister | | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | Looks like the PO swapped out the front hubs for '49-'54 Passenger hubs to convert it to 5 lug to match the rear. That is the hard part is figuring out what vehicle was used....the drum has the anti squeak springs aroud the outside, strange but at least the front and rear match...I am finding more and more of this truck that is not original...it is making this fun. Everyday I work on something and it is an adventure!
