0 members (), 138 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I'm looking to reduce rpms on the highway....I have a 1956 gmc with a 270....I have been told it has a 390 rear and would like to keep the original rear end in the truck ....but maybe change the ring and pinion to lower rpm's at highway speeds....anyone have any experience with this issue??
http://www.jalopyjournal.com/forum/...ring-pinion-gears.1015591/#post-11476035
Strongly consider buying an installation kit:
http://www.classicparts.com/1955-62...omplete/productinfo/93-514/#.VxjpKhMrKdE
http://www.classicparts.com/1955-62...ite-Kit/productinfo/93-515/#.VxjpOxMrKdE
Maybe some who has done the 3.38 swap will post about their experience.
Many people have done the 4.11/3.90 to 3.55 swap in earlier trucks.
GMC should have a Dana 45, not as easy to find as the G.M. corp axle or the Dana 44, threads on forum regarding the 45.
BC
1960 C60 pasture art
Apparently not all of them. My friend has a 56 GMC Suburban Carrier, 316 Pontiac, hydro and it has the same 3.90:1 corporate rear end as my 56 Chevy 3100. Everything is original as far as we can tell.
Fred
What series is your '56 (i.e. 100, 150) and what rear axle does it have?
BC
thanks for the response guys….I have a 1/2 ton 100 series..I'll be under the truck this weekend…not sure how to identify if it is a spicer or gm….lot's of conflicting info on the web…manual says it should be spicer 45….headed to Carlisle this weekend …..thanks for the help…...
The G.M. corp axle will have a round cover on the rear & the carrier bolt into the same shape opening in the front of the axle housing. Dana / Spicer axles have a 10 bolt cover with straight vertical sides.
BC
Well we took the cover off and found it to be a Dana 45.....with a 307!!! so I took off the 205 tires I had on just as project tires ....and swapped them for 31 10.50's and what a difference in RPM drop.....never thought there would be that much of a difference just in tire size....now cruises at 55-60 no sweat.....thanks for the info guys......by the way found a spare tire mount for a short bed stepside out at Carlisle...been looking for one for a long time.....swapped it for a front bumper from a chevy 3100...great find..........
