4 members (Hotrod Lincoln, Ponchogl, Peggy M, 1 invisible), 81 guests, and 2 robots.
Topics128,057
Posts1,055,816
#1161566 04/21/2016 2:45 PM
Howdy folks. I've been away for a while but I'm driving the old boy plenty smile
I've got a problem with arcing *I think. I can hear clicking from what sounds like electrical arcing under the hood and I sometimes get a mild shock from touching metal surfaces inside the truck.
I've got the usual braided ground strap and the connection is tight and clean.
The truck is converted to 12 volt.
Thanks in advance
Possibly related? I cleaned inside the dist. cap. Sprayed with WD40 and used dielectic grease on all fittings (spark plugs, rotor and coil).
Problem seems resolved.
Comments welcome, I'm working without a net!
Big Bolt Forum Moderator
if you can hear the arcing, my experience has been it is probably not the vehicle electrical (6 or 12v) but ignition. Sounds like you are on the right track with what you did on the dist cap etc. Another trick is to look under the hood at night (darker the better). The arcing you hear should show up at in the dark! (I have found some bad plug wires that way, or the coil wire as well!)
Mike
Good idea. I'll get on that. I think I'll add a extra ground strap to the firewall while I'm at it.
Carbon arcing on the distributor cap would show up in the dark.
If you're feeling a shock, it's not a 12V problem. That's not enough voltage to feel, unless you're using your tongue. Like the other guys suggested, concentrate on your high voltage ignition wires and the distributor. What you're probably hearing is a short to ground from one of the spark plug wires.
Problem went away after the aforementioned PM work.
Dang if only everything was that easy.
Did the same a while back. Nice shiny clean distributor cap. Nice and shiny. Forgot to wipe the inside and ...you get the results posted above. Nice shiny cap by the way.
Steve H
